Gray Marine Vee Drive
Old Marine Engine » Gears, Transmissions, and Propellers » Gray Marine Vee Drive « Previous Next »
Chris Mattoon
Username: chris_mattoon
Posted on Tuesday, November 14, 2006 - 08:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have a spec sheet for a 1950's Gray Marine Vee Drive, Model 113, Number 1294?
I need to know the max HP and RPM.
ross neels
Posted on Thursday, September 10, 2009 - 08:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris , like yourself I am seeking information about these Vee Drive Boxes .I have two , a left and a right hand unit .However they both have the output running the same way,counterclockwise.They are model 7:4 691 and 692.Theshafts are are horizontally offset.There is a number cast into the top of the actual gearbox casting , Timken5200W127 , probably the bearing numbers ??
Bruce Hall
Username: bruce
Post Number: 203
Posted on Friday, September 11, 2009 - 09:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Chris, From a catalog cut on the '30-'32 year gray motors. The V-drives were rated at 50-150 HP at 3000 RPM OR any engine developing a torque not greater than that of 200hp at 3000 RPM. Look for a period special catalog #51-B according to the catalog. Not what you're looking for but relavant.
Todd Vidgen
Username: todd_vidgen
Post Number: 137
Posted on Sunday, September 13, 2009 - 05:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Re the output shafts having the same rotation.
It is quite common to have one of the engines
running counter clockwise in a twin engine set up
so you would not have both props spinning in the same direction ,(the steering and handling would
be diabolical otherwise)Mercruiser do it alot
Keith Brayer
Username: nahma
Post Number: 14
Posted on Thursday, May 25, 2017 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking for a Gray Marine Vee Drive if anyone knows of one for sale.
Keith
[email protected]
