Post Number: 3939 Registered: 11-2001
| Posted on Thursday, December 29, 2016 - 06:54 am: |
* Unknown Marine Engines List 3 15. 15a. 15b. _____________________________ _____________________________ 16. 16a. 16b. * |
Steve Roskowski
Senior Member Username: modhydro
Post Number: 54 Registered: 08-2004
| Posted on Thursday, December 29, 2016 - 11:45 am: |
Here is another. It is a smaller sized engine That I'll have to pull some measurements from. It is a bit different in that the cylinder and crankcase is all one casting. The piston and rod goes in from the bottom via the access plate.
Post Number: 3940 Registered: 11-2001
| Posted on Thursday, December 29, 2016 - 12:18 pm: |
* Steve The intake drip oiler dates it approx 1907-10 Thanks for post, I have copied photos and added it to my unknown list ? * |
Post Number: 3941 Registered: 11-2001
| Posted on Thursday, December 29, 2016 - 03:38 pm: |
* Keith B. You mentioned a twin copper top unknown ? Maybe post it here. * |
Steve Roskowski
Post Number: 55 Registered: 08-2004
| Posted on Friday, December 30, 2016 - 03:54 pm: |
Here are the follow up dimensions to the single a couple of posts up. It is a 3 1/8" bore, 4" stroke with a 13 1/4" flywheel and 4 3/4" jug. |
Keith Billet
Senior Member Username: keith
Post Number: 478 Registered: 02-2002
| Posted on Friday, December 30, 2016 - 06:41 pm: |
I apologize for the poor pictures. I was hanging onto pallet racking with one hand and taking the pictures with a cell phone with the other hand. I believe this is a Canadian engine. At least I got it out of Canada. Keith |
Keith Billet
Post Number: 479 Registered: 02-2002
| Posted on Friday, December 30, 2016 - 06:44 pm: |
Post Number: 3942 Registered: 11-2001
| Posted on Saturday, December 31, 2016 - 12:37 pm: |
* Good post, with over 30 copper top engines in data base none match the crankcase design of this twin ? Put Canada Copper top in search and came back with 7 mfgrs, looked at each one and no match So this one will go in Uknown file for now ! This is an Unknown copper top that is similar but different lower casting ? * |
Post Number: 3943 Registered: 11-2001
| Posted on Saturday, December 31, 2016 - 06:59 pm: |
* Paul Gray has this unknown, I searched it a while ago but no name yet, He emailed this note that may have clues to its origin ? It is a 2-cycle, 3-port, 4" bore and stroke, aluminum crankcase. Cast iron cylinders and Pistons, head bolts are 1/2-12 so that puts it pre-1907. Funky three-piece rods...see pictures.. Missing the intake, exhaust and flywheel. Flywheel is tapered hub (pattern for one in background) These are places in the scavenging passage for rotating valves to throttle it, but not drilled out. No nameplate or places where one would have gone. Everything is matched stamped to indicate assembly order. I'm guessing first, early horseless carriage, second, marine or third, aero application.??? Very little wear, crank and bearings pristine I'm guessing a prototype...but for what? Thanks Paul 17. 17a. 17b. Keep those Unknown marine engines coming in we'll name one soon ?? * |
