Unidentified fishing boat gearboxes
Old Marine Engine » Unknown Engines - post here with photos » Unidentified fishing boat gearboxes « Previous Next »
Patrick Matthews
Posted on Monday, November 28, 2016 - 08:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Before hydraulics became common in small fishing boats, Monterey Clipper skippers could use a chain drive off the prop shaft, running through an old car transmission and some right angle gearboxes to drive the trolling "gurdies".
Anyone recognize the 3-way and 90� gearboxes in this 1950's image? The 90� units seem to have levers to disengage the drive.
unknown boxes
Robert
Username: robert
Post Number: 811
Posted on Thursday, December 01, 2016 - 11:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The 90� boxes are obviously cast brass or bronze from the verdigris colour, so probably made up by the same outfits that made the gurdies. The other trans looks like it might be from a small tractor or some other application where the shaft that drives the gurdies would have been the rear axle?
