Victor Maessen
Member Username: mvictor_be
Post Number: 5 Registered: 05-2007
| Posted on Thursday, May 31, 2007 - 05:42 am: |
This gearbox whas mounted on a wiscinsin engine Anyone have any info about the unit I found some numbers on the gearbox if someone can use this set let me know MFD PTA 5-15 BG-232 BH 175
Lawrence T Wolfe
Post Number: 244 Registered: 07-2003
| Posted on Thursday, May 31, 2007 - 01:57 pm: |
It looks to be a wisconsin gearbox. I have the manuel for the ahh,agh,etc series it shows cover number as BH 119, houseing number as BG 149-B. Your engine is smaller so it has differant numbers on a smaller gearbox. I guess you have an aen engine. The PTA letters do show in some wisconsin parts lists. |
Roger DiRuscio
Post Number: 245 Registered: 03-2002
| Posted on Thursday, May 31, 2007 - 02:08 pm: |
I have seen a very simular gear box on a bunch of plaster and cement mixers. Is yours an in and out box or does it have reverse? Roger |
Victor Maessen
Post Number: 6 Registered: 05-2007
| Posted on Thursday, May 31, 2007 - 02:57 pm: |
Roger, the gear has as far i know only free and forward. the inside has 2 tooth wheels and chains i have a good simular ingine but the axes is thicker the 4 bolts are not present
Roger DiRuscio
Post Number: 246 Registered: 03-2002
| Posted on Thursday, May 31, 2007 - 03:06 pm: |
As a in and out box there will be parts motors around if you need them. were you planning on putting this in a boat? |
Victor Maessen
Post Number: 7 Registered: 05-2007
| Posted on Thursday, May 31, 2007 - 05:30 pm: |
the compleet unit was standing in a 14ft boat, i'm planning to place the stuart turner P5ME in the boat |
Roger DiRuscio
Post Number: 247 Registered: 03-2002
| Posted on Thursday, May 31, 2007 - 05:41 pm: |
I agree with Lawrence above, The engine looks like the AEN, AENL, AENELD series. They were rated up to 9.2 HP depending on RPM setting |
Roger DiRuscio
Post Number: 248 Registered: 03-2002
| Posted on Thursday, May 31, 2007 - 05:45 pm: |
oops one too many E's in that last model number |
Victor Maessen
Post Number: 8 Registered: 05-2007
| Posted on Thursday, May 31, 2007 - 05:46 pm: |
The black one needs just a pull and runs perfect, the other where the gearbox came off is good for parts |
