J.J. Parker engine/Fulton, NY
Old Marine Engine » One and Two Cylinder Gas Inboards » J.J. Parker engine/Fulton, NY « Previous Next »
Peter Hunn
Posted on Sunday, January 20, 2002 - 08:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Having recently acquired a small, circa 1905 J.J. Parker single built in my community (Fulton, NY), I'm looking for information on this little marine engine. It looks like the one pictured in Wendel's book (but w/out the propeller/shaft/clutch mechanism). There's no carburetor, but I'm not sure where one might be fitted? It has an igniter as well as what appears to be a spark plug hole!?! Any info on the Parker will be greatly appreciated. Thanks-
Posted on Sunday, January 20, 2002 - 08:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter,
How about posting a picture of it here...? Or email a picture to me and I can post it here for you.
It has an igniter and a spark plug hole? You don't think it could be an ignitor and a threaded hole in the head for the stationary electrode of the igniter similar to the early Lathrop engines? Or maybe a replacement head with the hole for the spark plug that allowed the engine to be converted from make'n'break to jump spark?
Regards,
Andrew
Keith Billet
Posted on Tuesday, January 22, 2002 - 10:19 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter, I have a three cylinder Parker. It is a somewhat unsual engine in that it is ignitor fired from a side shaft. It is small and especially neat. I do not have any info on the company, and would appreciate if you would share any that you may receive. I will take some pictures and email them if I can get your address. ([email protected])
Posted on Tuesday, January 22, 2002 - 02:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is Keith's engine....
left
right
Richard Day
Posted on Wednesday, January 23, 2002 - 06:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Keith, I would love to see that engine at the CMM show in May. It looks like a jewel. Regards Dick
Keith Billet
Posted on Thursday, January 24, 2002 - 04:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick, I will bring the PARKER to the Calvert Show.
Keith
Tom
Posted on Tuesday, January 29, 2002 - 08:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Attached is a picture (from the cold garage)of my little "New Parker" made by the G J Emeny Co also of Fulton, NY. It has a little preheater stove by the exhaust manifold and a 1/2" pipe intake just below the stove. Mine is also missing carb. Mine is a 3 port so could use any carb or mixer without needing a check valve.
Flywheel dia 10" Height 18"top to bottom.
Tom Stranko
parker1
parker2
