Gray Model 80 RD engine
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Model 80 RD engine « Previous Next »
Jim Thomson
Username: brownboat
Post Number: 15
Posted on Thursday, June 30, 2016 - 05:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Engine is 80 HP, built 1962, four cylinder, complete. Am parting out to make room in my shop. If you have a need let me know. What isn't sold in the next couple weeks is going to the scrap metal dealer. Alternator appears to be aftermarket replacement. Otherwise engine appears to be basically original.
peter siegel
Username: vtpete
Posted on Saturday, July 16, 2016 - 04:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
do you have the carb. i am looking for a bb1 carter up draft.
Jim Thomson
Username: brownboat
Post Number: 16
Posted on Thursday, July 21, 2016 - 01:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter, Carb is a Zenith updraft. tag # 11995.
peter siegel
Username: vtpete
Posted on Monday, July 25, 2016 - 12:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hay Jim, i have 70 rd with a carter bb-1 on it,do think it will fit in its place?
Jim Thomson
Username: brownboat
Post Number: 17
Posted on Tuesday, July 26, 2016 - 12:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have no idea if it would fit.
