Thrust bearing
Old Marine Engine » Blaxland » Thrust bearing « Previous Next »
Dennis Stapleton
Username: djstapo
Posted on Wednesday, June 30, 2021 - 04:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am doing up a blaxland twin. What is the purpose of the nut at end of crankshaft that tightens against the gear drive
Does it have anything to do with the timing ? Or just to hold it in position. Also do you put the pistons in the heads and the attach to crankshaft or put heads on after pistons are bolted on
Rodney David Gillespie
Username: gill
Posted on Friday, September 17, 2021 - 07:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I remove the gudgeon pins fit the rings to the pistons and lock the piston in position with timber through the port and replace the gudgeon. It needs 2 people or you can pack the piston up with spacers just giving your self room to fit the pins and circlips. Don't forget to fit the base gasket first.
