1906 Kahlenberg single
Old Marine Engine » Boats with Early Inboards » 1906 Kahlenberg single « Previous Next »
bobstuff
Username: bobstuff
Posted on Tuesday, December 26, 2017 - 03:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I�m working on a nice complete engine and would like to know what color the engine was painted? Also where can I get some original grease cups for the crank?
Post Number: 947
Posted on Tuesday, December 26, 2017 - 10:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Most of them that I have seen were painted black but dunno if that was the factory colour.
Black will make your shiny brass stand out.
I think Richard Durgee can help you figure out what style of grease cup your engine should have from the advertising info.
Post Number: 1350
Posted on Wednesday, December 27, 2017 - 06:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Search Kahlenberg in the bar above, you will see some that may help.
robert
Username: robert
Post Number: 915
Posted on Thursday, December 28, 2017 - 08:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just had a look at three different gas Kahlenbergs and all had the Lunkenheimer "Marine No.-" grease cups with the "T" handles. That is probably pretty conclusive, but Kahlenberg Bros. are still going in Two Rivers WI and can probably tell you for sure what was used.
Even better, they probably have the original sales records if you have the engine serial number.
BTW, we'd all appreciate photos, before, after or during!
