Keel cooler
Old Marine Engine » One and Two Cylinder Gas Inboards » Keel cooler « Previous Next »
louq
Username: louq
Post Number: 9
Posted on Sunday, February 14, 2016 - 09:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm making a keel cooler out of copper pipe and would like to hear some suggestions on what type of solder to use. Lead free, lead/tin, silver(what %)or what else?
Thanks,
Lou
johnoxley
Username: johnoxley
Post Number: 152
Posted on Sunday, February 14, 2016 - 11:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Assuming you are on salt water, would not use ordinary solder. I'd use 45% Silver solder.
bruce
Username: bruce
Post Number: 524
Posted on Monday, February 15, 2016 - 01:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Lou, Check out "Pro-press" fittings. Non solder copper joints using a power crimp tool (tool can be rented )
