Replacing Scebler Model D float |
Roger Shields
Member Username: rshields
Post Number: 7 Registered: 02-2013
| Posted on Monday, February 15, 2016 - 08:26 pm: |
I have a Model D and tried to replace the float. However I cannot for the life of me figure out how to hold the little nut which is under the float when the float is installed, and make up the little bolt to secure the float to the control arm. Any and all help and suggestions are much appreciated. |
Post Number: 1141 Registered: 07-2002
| Posted on Monday, February 15, 2016 - 09:10 pm: |
You should be able to start the nut on the float out of the carb, leave it loose and wiggle it into place, align and tighten it. |
Roger Shields
Post Number: 8 Registered: 02-2013
| Posted on Tuesday, February 16, 2016 - 08:14 pm: |
I may misunderstand the advice, so apologies if I have. There is a hole not a slot so There is no way to wiggle the metal tang into place on the float. I actually cannot even remove the old floaty6 . The nut spins in the float so I can't extract the bolt. |
Post Number: 1142 Registered: 07-2002
| Posted on Wednesday, February 17, 2016 - 06:34 am: |
If you start the screw in the float but don't tighten it the float arm will rotate, you can work the float into the bowl, align the lever and tighten it. |
