Detroit 453 injectors
Old Marine Engine » Diesel Inboards » Detroit 453 injectors « Previous Next »
Mike Todd
Posted on Friday, January 22, 2016 - 04:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My Detroit 453 in my 28 foot boat is hard to start if it sits for 2 or more weeks. It needs to turn over for about 60 seconds or I have to use stater fluid. However if I get it started and run it, the motor starts right up the next day even 5 days later it will start right up.
Would replacing the injectors help this? Any other ideas how i might get it to start up easy even after it sits for a couple weeks?
Thanks, Mike
ak453
Username: ak453
Posted on Friday, January 22, 2016 - 05:00 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just regesterd and am now AK453
jimmys
Username: jimmys
Post Number: 60
Posted on Friday, January 22, 2016 - 03:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike,..Sounds like you have a leak on your primary side of the Fuel Filter,..Line from the tank to the Primary Fuel Filter,.or Secondary Filter,..If you have a loose fuel line connection,..The engine looses it's fuel pressure prime over time and could suck air into the system.Check all the fuel line connections.
