NL2 Palmer Marine engine
Old Marine Engine » Palmer Engine Co » NL2 Palmer Marine engine « Previous Next »
Charles Wyman
Username: farmer444
Posted on Thursday, May 05, 2016 - 09:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have 8 hp #L835323 in dory all there with reverse gear need info going to starting it
Charles Wyman
Username: farmer444
Posted on Sunday, May 08, 2016 - 10:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is NL2, is engine oil & reverse gear oil connected, if not how do check engine oil
Charles Wyman
Username: farmer444
Posted on Thursday, May 19, 2016 - 08:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I got the motor running I believe you check oil in tranny it say keep one third full. But like to make sure this is the motor oil too. When running the sight glass is pumping oil. what oil would you use in this motor. thank on any info, Hoping to try in water soon
Post Number: 1133
Posted on Friday, May 20, 2016 - 10:20 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Check for a brass wire sticking up on the aft Port side of the crankcase of the top half supporting the cylinders. It should have a cork float about 3" dia. by 1/2" thick. should move up and down freely in brass oval top guide. Trans mission is not connected to reverse gear in most models. You can take off the crankcase cover on either side of the cylinder portion and look for oil level which the cranks cause the rods to dip in the crankcase oil about 3/4".
Use typical #30 car motor oil in engine crankcase and reverse gear crankcase.
Engine normally is timed to run counter clockwise.
Charles Wyman
Username: farmer444
Post Number: 7
Posted on Monday, May 23, 2016 - 08:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Richard for this info very much needed. Lot of info here, You and the others saved me. My motor was missing the N gasket on the Schebler carb, cut new one got running pretty good. Thanks again Hope to put some picks on of dory & motor soon
