Brass union tees
Old Marine Engine » Miscellaneous » Brass union tees « Previous Next »
raa
Username: raa
Post Number: 113
Posted on Monday, February 08, 2016 - 02:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Help
I am restoring a 3 cylinder Tuttle which has hard all hard plumbed 1/4" water lines. I need two 1/4" tees which are not available anymore. I guess you could call them union tees. One tee has the union port on the drop leg and the other tee has the union on the run leg.
If anyone has one or both of these tees I would sure like to buy or trade for them.
cheers
Dick
union tee
union tee
union tee
Post Number: 1140
Posted on Monday, February 08, 2016 - 05:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks like one more pattern Dick. I know this is your winter project, are you going to run out of winter before it's done?
raa
Username: raa
Post Number: 114
Posted on Monday, February 08, 2016 - 07:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Probably will run the clock out on this one.
dick
