louis mcnair
New member Username: louis_mcnair
Post Number: 1 Registered: 12-2015
| Posted on Sunday, December 20, 2015 - 01:37 am: |
Hi everyone, here are a couple of pictures of a little marine i am trying to get my hands on. Its quite a small engine with a few interesting features and details and i was hoping someone would be able to put an ID on it. I do have some more pictures as well if that would help Cheers, Louis |
louis mcnair
Post Number: 2 Registered: 12-2015
| Posted on Sunday, December 20, 2015 - 01:39 am: |
miro forest
Senior Member Username: miro
Post Number: 834 Registered: 11-2001
| Posted on Monday, December 21, 2015 - 07:49 am: |
You are certainly right - it does have interesting features. From the pictures, it's a challenge to figure out where the drive it taken from and where the thrust bearing would be. Was there a flywheel with the engine? The grease cup aft of the magneto is the most interesting. Miro |
Post Number: 2198 Registered: 01-2002
| Posted on Monday, December 21, 2015 - 07:59 am: |
My guess is that the shaft goes under the mag and that is where the thrust bearing my be, hence the grease cup. Ernie |
louis mcnair
Post Number: 3 Registered: 12-2015
| Posted on Monday, January 04, 2016 - 05:48 pm: |
No flywheel with the engine Miro, yes the shaft is hidden under the mag in those photos and exactly what that grease cup is for Ernie, here are a couple more pictures
Scott Noseworthy
Post Number: 257 Registered: 02-2008
| Posted on Tuesday, January 05, 2016 - 02:43 pm: |
from the top view the cylinder is off set maybe their is a big counter weight in the crank case? |
