Ducati 2 cyl, 22HP inboard air cooled...
Old Marine Engine » Diesel Inboards » Ducati 2 cyl, 22HP inboard air cooled marin diesel « Previous Next »
John Nicolas
Posted on Thursday, March 24, 2005 - 06:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi
I have a Ducati 2 cyl,
22HP inboard air cooled marin diesel.
Anyone interested
Located in Sweden
Mal McKay
Posted on Friday, February 24, 2006 - 04:55 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi John j
I have found a ducatti 2cyl air cooled engine in Australia and am wondering how old it might be and if they are rare?
poker casino832
Posted on Monday, March 06, 2006 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 892
Dave Benyon
Posted on Monday, November 27, 2006 - 02:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
They seem to be pretty rare nowadays. Allegedly these were actually made by VM Motori of Italy. They used to have a plant at Trieste and it would seem logical that the boat engines were made there. VMs main plant is at Cento and Trieste was allegedly disposed of years ago. If you email VM, they will tell you that these engines are "too old".
Diesel Power of Mitcham Surrey UK used to hold spares but they say they now have very little left, the phrase "too old" pops up again.
Possibly clones of these are still being made in low wage countries, although as the design used expensive aluminium this is not very likely. Lister clones are still being made in India but these engines use much less expensive cast iron.
If the engine still turns you should be able to restore it if you can do it yourself. Unfortunately not many boatyards have the skills or patience needed these days.
Good luck and best regards from Dave.
removal_man
Username: removal_man
Posted on Thursday, February 01, 2007 - 04:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, i have a ducati IS 19 marine diesel with no gear box for it though. if any one knows of one that would fit i would be greatful. thank you.
ygovon
Username: ygovon
Posted on Friday, November 20, 2009 - 07:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dear sirs,
there is only one person in the U.S. able to supply every sort of info about the Ducati mono & double cylinder little diesel units and his name is Dale Chambliss in Houston Tx. He also had a huge inventory of spare parts for such engines. You can still try to contact him at [email protected]. Good luck.
Best regards.
B Wheeler
Posted on Friday, December 31, 2010 - 11:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Please could you direct me on purchasing a Ducati Marine Diesel 2 cylinder aircooled Engine
I live in New Zealand Thank you
paulvec
Username: paulvec
Post Number: 19
Posted on Friday, June 10, 2011 - 08:33 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
hi, I have a ducati single cylinder engine available in New Zealand
Gus
Posted on Tuesday, October 15, 2013 - 04:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi i have a 22hp ducati marine engine which is rebuilt and running if anyone is interested gus Australia
ekim
Username: ekim
Posted on Wednesday, September 02, 2015 - 04:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone have any information on fuel reticulation for a Ducati 22hp air cooled marine diesel installation. Motor is brand new.
Mike Hughes
Posted on Wednesday, September 02, 2015 - 05:08 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi, I have a ducati IS18 & a IS22 for sale here in the UK if anyone interested. The IS22 also has the gearbox attached.
hawkman
Username: hawkman
Posted on Sunday, December 11, 2016 - 11:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Mike. Just seen your posting from 2015. Would you happen to still have your Ducati engines ?
