Gies gear company
Old Marine Engine » Gears, Transmissions, and Propellers » Gies gear company « Previous Next »
David Woodworth
Username: david_woodworth
Posted on Wednesday, April 24, 2013 - 06:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just got a Gies special no. 1 pat june 11 1907 and a larger Gies model A I would like to know what one i would use with a 5or 6 hp motor. Anyone know someone i could talk with who knows how to restore them.
Searcher
Username: searcher
Post Number: 562
Posted on Wednesday, April 24, 2013 - 08:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
They are pretty simple inside. I took a bunch of photos as I dismantled mine to make sure I could put it back together again. Didn't really need them.
This Gies ad shows how to calculate the size needed.
Keith Billet
Username: keith
Post Number: 390
Posted on Wednesday, April 24, 2013 - 08:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Interesting Ad. Based on it, if you operated your engine at 800 RPM #1 would handle 12 hp.
Searcher
Username: searcher
Post Number: 563
Posted on Thursday, April 25, 2013 - 10:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are some of the photos I took of a Gies No. 1 Special while dismantling it. The stamped 1916 looks like the date of manufacture but I suppose it could be an assembly number. The patent number for the Gies is 856462.
Christopher Kirk
Username: ceekay
Posted on Tuesday, March 14, 2017 - 10:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello! Great looking reverse gear. I have the same one that I've just disassembled.
Any Issues since you've put it back together? What sort of grease do you put inside and how often do you replace it? Mine appears to be complete except for the brass grease cup.
Thanks,
CK
Hazel Coomes
Username: oldboatparts
Posted on Monday, August 26, 2019 - 02:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have a Model A Reverse gear, by GIES Gear Company, in reasonably good condition, that has been kept out of the weather, for sale? Asking price?
