Engine Oil
Old Marine Engine » Multi Cylinder Gas Inboards » Engine Oil « Previous Next »
wheels4u22
Username: wheels4u22
Post Number: 15
Posted on Sunday, May 31, 2015 - 08:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My Lycoming UAB calls for 30 weight oil. Engine oils have improved dramatically over the years and I am looking for some recommendations. Because of the Joes gear I heard I should stay away from synthetic as it will cause it to slip in gear. Should I use the same as was called for? Detergent or not?
scott_n
Username: scott_n
Post Number: 245
Posted on Monday, June 01, 2015 - 09:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I use non detergent 30 weight and change once a year in my 1955 Chris Craft still runs good after 25 years
drrot
Username: drrot
Post Number: 186
Posted on Monday, June 01, 2015 - 10:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I also recommend non detergent straight weight. I get it at the local farm supply store.
If you must use synthetic pay up for Harley Davidson oil. Their oil is designed for engine and clutch.
wheels4u22
Post Number: 16
Posted on Monday, June 01, 2015 - 07:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks all for your input. I appreciate it.
ldobbins
Username: ldobbins
Post Number: 169
Posted on Monday, June 01, 2015 - 07:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Greetings all,
Several people who are successful at building old marine engines are having good luck with Amesoil synthetic marine straight weight oil. I am told but not verified that it is working well over the temp range in the transmissions.
Cheers,
Lew
robert
Username: robert
Post Number: 678
Posted on Friday, August 28, 2015 - 11:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A bypass filter is a particularly good idea in a marine engine. There are several that use a tight roll of toilet paper as the filter element. Cheapest and best filter there is. Frantz and Motorguard come to mind. Many users never drain their oil again, just replace what is lost in changing the TP roll. Check it out.
