Starter - 1931 model 6-50
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Starter - 1931 model 6-50 « Previous Next »
Bill Michaels
Username: cidermillbill
Post Number: 8
Posted on Sunday, July 19, 2015 - 09:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Housing on end of starter broke. I need some advise on how or who can repair it.
Post Number: 1079
Posted on Sunday, July 19, 2015 - 01:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would braze it. Tack it in several spots, V out the groove between the tacks, braze, V under the tacks and finish brazing. Look for someone in your area familiar with brazing, should be as strong as the cast, what caused the break?
Jim Staib
Username: drrot
Post Number: 187
Posted on Thursday, July 23, 2015 - 10:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
can you read the numbers after PS?
That is a part number.
James O'Brien Mans
Username: jjmans
Post Number: 21
Posted on Thursday, July 23, 2015 - 10:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Is there such a thing as a Hercules ZXB? I have a 4 cylinder marine engine that I am restoring and need some help. Thanks.
James O'Brien Mans
Username: jjmans
Post Number: 22
Posted on Friday, July 24, 2015 - 01:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 4 cylinder engine that has been converted over to marine use and it has a serial number of: 1157066ZXB. I'll be needing parts and need a source for those replacement parts.....Need help please! Thanks.
Jim Thomson
Username: brownboat
Post Number: 9
Posted on Saturday, July 25, 2015 - 05:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What parts do you need for the ZX engine? I have some parts for the Hercules ZX. Got a picture of the engine?
James O'Brien Mans
Username: jjmans
Post Number: 23
Posted on Saturday, July 25, 2015 - 08:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim Thomson.......sent you an email with a photo of the machine.......don't know how to post a photo on this site.....
