A (not so ) Silent DisPro
Old Marine Engine » Boats with Early Inboards » A (not so ) Silent DisPro « Previous Next »
Post Number: 818
Posted on Sunday, August 23, 2015 - 10:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I had some multiple troubles with the DisPro recently. A broken float in the carb, and a wad of oily carbon in the muffler.
I had even suspected the ignition.
So, after repairing the carb, and cleaning the muffler, and checking the ignition and charging the battery, I started to put things back together.
But this time, I wanted to know which issue was the cause i.e. I suspected the carb was the fault.
So I rigged up a dry exhaust just to test out the other things before putting it all back together.
Usually DisPros a pretty quiet - except with the dry exhaust - not so much.
Here's the video
https://www.youtube.com/watch?v=Z-eAGV8cbCc&feature=youtu.be
Miro
