Charging two batteries with original ...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Charging two batteries with original generator/regulator « Previous Next »
Christian Gould
Username: ketchcng
Posted on Tuesday, May 26, 2015 - 11:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have the original, rebuilt, tested generator and regulator from my Graymarine Sea Scout 91 on our 1961 sailboat. I am having trouble charging two battery banks and was curious if this should be possible?
I rewired the boat and assume that is the problem.
Thanks a lot.
