Coil
Old Marine Engine » One and Two Cylinder Gas Inboards » Coil « Previous Next »
greencorn
Username: greencorn
Post Number: 11
Posted on Wednesday, May 27, 2015 - 07:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
When connecting the coil does it make any difference which poles on the coil are attached to the engine? Negative or poisitve to the igniter?
Post Number: 1065
Posted on Wednesday, May 27, 2015 - 08:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I guess you're using an automotive coil for a low tension coil. Polarity wouldn't make a difference. If you were using the engine full time it would be best to run it one way for a week and reverse it the next wee to keep eroding of the points even.
