Part Identification- Gray Marine
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Part Identification- Gray Marine « Previous Next »
Josh Lenhard
Username: lenny28fb
Posted on Wednesday, March 25, 2015 - 12:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know where I could find a parts numbers for Gray Marine? I have a Part Identification book but it doesn't list any part numbers. I bought a box of old parts off of Ebay hoping some would fit my Gray-100. I think some are for 4 cylinder and 6 cylinder engines. Any help would be greatly appreciated!
70590 Main Bearing Kit
70593 Main Bearing Kit
71593 Ball Bearing
5078 Ball Bearing
75360 Seal
66126 Oil Seal
74366 impeller
71594 Bearing
70585 Rod Bering Kit
70582 Rod Bearing Kit
68682 Bearing
68681 Bearing
Thanks,
Josh Lenhard
Bruce Hall
Username: bruce
Post Number: 484
Posted on Wednesday, March 25, 2015 - 03:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My original 1950 Graymarine maintenance hand book includes a section that has a condensed parts list.
The Model 100 main bearing set : front, F800G3271; Intermedite,F800G3251; Rear,F800G3361
Part numbers for 1950 models are generally predicated with a letter. Remember these are Graymarine part numbers from 1950.
Ned Lloyd
Username: ned_l
Post Number: 21
Posted on Tuesday, April 21, 2015 - 01:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You might have an easier time finding parts if you can figure out which model Continental engine the Gray 100 is. Might it be the same block & internals as the Gray 109? ... The 109 is a Continental F226.
