williams_453
New member Username: williams_453
Post Number: 1 Registered: 04-2015
| Posted on Tuesday, April 14, 2015 - 05:20 am: |
Hi guys & girls, first post here. Looking for a bit of info on an issue in our new (old) boat. It has, what I think is 2 x 4-53 Detroit diesel 2 stroke motors. It doesn't seem to be holding fuel pressure, and it wont idle/run at low RPM. The fuel rail pressure gauge seems to be getting to 5 max (the other motor runs at 15-20), and will randomly drop to 0 and the motor will die. I cant seem to figure it out. Has anyone had this issue? also, where is the pressure sender on these motors? Any help would be terrificly appreciated |
jimmys
Senior Member Username: jimmys
Post Number: 54 Registered: 01-2011
| Posted on Tuesday, April 14, 2015 - 01:52 pm: |
You probably have a Fuel/Water Seprator Filter plugged, mounted someware prior to the engine, on the fuel line form your fuel tanks,..the Container is full of water and won't let enough fuel through..or a Plugged Primary or Secondary Fuel Filters on your engine,..last try would be a worn out Fuel Pump...I have one of these Engines/Used in stock. |
