Shipwreck engine
Old Marine Engine » Unknown Engines - post here with photos » Shipwreck engine « Previous Next »
Peter Illidge
Username: peteillidgegbrmpagovau
Posted on Thursday, April 30, 2015 - 09:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi All, have a bit of a challenge for you all. We discovered a shipwreck on the Great Barrier Reef, Queensland, Australia and can not identify it. We thought if we could identify the engines and perhaps a year of manufacture this would help us. This is a twin engined timber vessel about 43 m (140 feet) long. The engines seem to be joined with a cross bar.
Thanks in advance for your help.
cheers Pete shipwreck engines 1shipwreck engine 2shipwreck engine 3shipwreck engine 4
Charles Holmes
Username: jimmys
Post Number: 55
Posted on Friday, May 01, 2015 - 02:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It appears to be a 4-51 Detroit GM Diesel Marine Engine, built in the Early 1950's. I have one listed on eBay, listing # 381228883898....So you can compare the pictures,...especially where the Heat Exchanger is mounted at the rear of the engine and the Marine Gear Box and Exhaust on the front of the engine.
Peter Illidge
Posted on Sunday, May 03, 2015 - 06:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Charles,
thank you very much for IDing this motor for me. I knew there would be someone out there that could go yep that's a whatever. Fantastic. Thank you very much. cheers Pete
