Post Number: 3528 Registered: 11-2001
| Posted on Tuesday, February 24, 2015 - 07:04 pm: |
* WHAT ? _______ no one has ever listed this Engine ??? The West Haven Motor Company established 1903, incorporated December 1906, I.A.Watrous Founder 1903 and President of Inc Company filed for dissolution 1907.
jeffk
Member Username: jeffk
Post Number: 14 Registered: 04-2009
| Posted on Wednesday, February 25, 2015 - 11:26 am: |
The engine above appears to be fitted with a Holley Bros. carb. |
Post Number: 3529 Registered: 11-2001
| Posted on Wednesday, February 25, 2015 - 02:38 pm: |
* Model L 1906 ad
bcm
Senior Member Username: bcm
Post Number: 64 Registered: 11-2009
| Posted on Thursday, February 26, 2015 - 10:19 am: |
Referring to the advertisement in Richard's first post - "Mr Watrous has just patented an automatic reverse switch for two stoke motors which make it possible to reverse an engine from any part of the boat. The feature of this little switch is that a solid propeller and shaft can be used" Here is patent # 839358 published Christmas day 1906. How the swtich works: 1 - To reverse the operator stops the engine by pulling detail 38a. 2 - This opens the electric contact between details 10 and 2a and at the same time sets a trigger at details 15 and 16 (figure 4) that hold the contacts open. 3 - According to Mr Watrous's claim when engine slows to zero speed, detail 23 strikes detail 20 releasing the trigger and reestablishing ignition as electrical continuity at 10 - 2a is again established. This occurs before TDC thus engine operates in reverse. At other times centrifugal force prevents detail 23 striking detail 20. 4 - No mention of how ignition timing is set from a remote location,however the image in Richard's post shows what may be a timing mechanism attached to the front face of the cylinder?? ******************* I suspect the Reversing Switch was intended to provide a sales advantage as most two cycle users were probably unable or uninterested to master reversing on the fly. Barry
Post Number: 3531 Registered: 11-2001
| Posted on Thursday, February 26, 2015 - 02:50 pm: |
* Barry I looked at this cool old patent when researching The West Haven Motor Co.! I like the way you explain it-- Always appreciate your input and posts! * |
