Chris Nauta
New member Username: cn2000
Post Number: 1 Registered: 08-2014
| Posted on Monday, August 25, 2014 - 08:23 pm: |
Hi Folks, I couldn't get the classifieds to open up so I am posting here, sorry. This engine is close to hitting the scrap yard, so I thought I'd give you guys a shot at it first.... I have a 4cyl Gray Marine engine with a mating paragon reverse gear. It is was run in fresh/brackish water only until the previous owner started removing the cylinder head to fix a seized/broken off spark plug. It sat in his barn for 35+years after that. I have come to the conclusion that I probably will never get around to fixing it up. Let me know if you're interested and I'll send you pics/info etc. Thanks. Located in Sacramento, CA You may call 410-926-800four. on Pacific time
Roger DiRuscio
Post Number: 580 Registered: 03-2002
| Posted on Monday, August 25, 2014 - 08:52 pm: |
what did you want for it Chris, I am only 2 hours away from you Roger |
Chris Nauta
Post Number: 2 Registered: 08-2014
| Posted on Monday, August 25, 2014 - 11:29 pm: |
Roger, call me 410 926 800four Up to 10pm is ok. |
Chris Nauta
Post Number: 3 Registered: 08-2014
| Posted on Saturday, September 06, 2014 - 03:09 pm: |
Last chance on this.... will be scrapped after 9/15 if no one wants it. |
Don M. Roberts
New member Username: innerbanks
Post Number: 1 Registered: 01-2015
| Posted on Tuesday, January 20, 2015 - 10:07 am: |
Do you still have the "feet" that go between the motor mounts and the flywheel/timing cover shield? |
Chris Nauta
Member Username: cn2000
Post Number: 4 Registered: 08-2014
| Posted on Friday, January 23, 2015 - 02:07 am: |
Don, I'm not quite sure what you're talking about. If you look at the first photo, you will see 2 brackets to mount the engine. There are 4 of these available if you need them. |
