Palmer 134 - Transmission work |
davidkirshoff
New member Username: davidkirshoff
Post Number: 3 Registered: 09-2014
| Posted on Saturday, September 06, 2014 - 05:33 pm: |
I recently acquired a 1941 26 foot sloop with an inboard Palmer 60 horse engine. The transmission is not working at the moment, and I would like to remove it to bring it somewhere to have it worked on. My goal is to do this with the boat in the water - perhaps lift the engine off its mounts, slide it forward to remove the shaft from the transmission, and then unbolt and remove the trans. I am basically just looking for advice, as this is the first time I have ever attempted anything like this, and this is also my first boat. Also looking for anyone in the New York tristate area who could potentially look at and/or work on the transmission. Any info would be greatly appreciated. Thanks a lot. David |
Senior Member Username: miro
Post Number: 772 Registered: 11-2001
| Posted on Saturday, September 06, 2014 - 09:18 pm: |
It might be better if you pulled the engine along with the transmission. I think they share the oil sump and if you separate them while it's in the hull, you'll get oil all over everything i.e. a mess that you will have to clean up by hanging yourself by the ankles from the over head rafters. Don't ask how I know this. Miro |
