Volvo Penta MD2B wiring help wanted |
pia
New member Username: pia
Post Number: 1 Registered: 10-2014
| Posted on Thursday, October 09, 2014 - 06:57 pm: |
I'm looking for a information on how to connect my oil pressure and engine temp gauges to the engine. |
oslin04
Senior Member Username: oslin04
Post Number: 76 Registered: 10-2006
| Posted on Friday, October 10, 2014 - 05:12 am: |
Hi Pia, if you have a single terminal oil and temp sensors the supply comes from the ignition switch via a warning light or gauge to the temp and oil pressure switch earthing through the engine block, If you have a twin terminals on the oil and temp sensors the supply comes from the ignition switch via a warning light or gauge as before but the second wire from the sensor is an earth return to the main earth block on the system. Hope this helps Keith. |
