Blacksland inboard engine
Old Marine Engine » Boats with Early Inboards » Blacksland inboard engine « Previous Next »
mikychiks
Username: mikychiks
Posted on Monday, August 25, 2014 - 07:57 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hey I am new to this site though I've come into the possession of a really cool putt putt . Which I'm pretty sure has a single cylinder blacksland motor on her running off a lucas magnito . It took me a while to get her running again but once I managed to after replacing nearly every thing but the main stuff . Long story short , last time I started it it rattled a bit and due to the age of the manifold it broke and have no idea where to get a new one . So any suggestions would be great . I know you guys probably know this already but the piece straight from the engine to the muffler . Cheers .Mick
Post Number: 771
Posted on Monday, August 25, 2014 - 10:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think you'll have some challenges getting a replacement.
The better approach may be to find a welder that KNOWS hows to weld or braze cast iron. It can be done and can be done well. But it does need some one who has the knowledge / understanding.
I think a braze repair would probably work quite well and there is less heat stress on the part being repaired.
And PLEASE, don't try to do it yourself. It will be worth the money to get it done by and experienced guy.
Are you running in fresh water or salt water?
marks
Username: marks
Post Number: 160
Posted on Monday, August 25, 2014 - 05:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Mick,
You can get a new replacement from Brett. His details are in this post http://www.oldmarineengine.com/discus/messages/3452/258524.html
ssilent11
Username: ssilent11
Posted on Wednesday, August 27, 2014 - 04:54 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI,
If you cant get a new replacement I can give you a secondhand replacement. let me know how you go.
mikychiks
Username: mikychiks
Posted on Thursday, September 04, 2014 - 12:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ssilent11 . Happy with 2nd hand one . A new one will cost me a small fortune .
Marks . Salt water mostly I think .
ssilent11
Username: ssilent11
Post Number: 7
Posted on Thursday, September 04, 2014 - 05:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Mick,
Give me your address and I will post it to you.
Just click on my user name for address.
Glad to be of help, and keep another Blaxland running.
