Palmer 60 not getting fuel to number 3 |
Thomas leddy
| Posted on Sunday, June 08, 2014 - 05:54 pm: |
My p 60 isn't getting fuel to number 3 cylinder could it be a blockage in the intake manifold or a stuck valve |
David Grosse
Member Username: davidg
Post Number: 20 Registered: 11-2010
| Posted on Monday, June 09, 2014 - 09:40 am: |
Thomas, You can find out if you have a stuck valve by doing a compression test. If one is stuck, you will not have compression in that cylinder. It is also not likely that you will have a manifold blockage to just one cylinder. Good Luck, David |
