Buchanan Rocket 6 cyl Engine
Old Marine Engine » Boats with Early Inboards » Buchanan Rocket 6 cyl Engine « Previous Next »
smckeown
Posted on Sunday, October 06, 2002 - 09:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Would like to identify the year of a Buchanan Rocket 6 cyl engine and trans, Serial #135-729050
or a source of info to search.
Posted on Monday, October 07, 2002 - 11:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You can try calling Hugh MacLennan in Port Carling, Ont ( Hugh Maclennan and Sons Ltd, I think) . He owns what once was the Seabird factory which used Buchanan engines almost exclusively. It still operates as a marina and he still does valve jobs and other engine repair on Buchanan's.
I suspect he has a good collection of hard to find engine parts too.
The library in Orillia ( where the Buchanan factory was located) has very little info and I understand that the building which housed the factory is about to be torn down.
Jim T
Posted on Monday, April 12, 2004 - 10:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Are you still looking to identify year for your Buchanan Rocket engine and transmission?
Robert McClintic
Posted on Wednesday, April 14, 2004 - 08:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
You might try Stan Hunter in Milford Bay Ontario (about 5 miles from Port Carling on Lake Muskoka) Stan specializes in restoring Seabird Boats.
Glenn Hodgkinson
Posted on Sunday, June 27, 2004 - 05:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Try Parry Automotive Limited. They still remanufacture these engines and they have the original "build" book from the F.L. Buchanan Company. Contact Glenn via email at [email protected] or call (705) 325-1345.
cobaltbill
Username: cobaltbill
Posted on Thursday, May 29, 2014 - 12:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looking for a water pump assembly for a 1955 Buchanan 6 cylinder rocket
Post Number: 764
Posted on Thursday, May 29, 2014 - 09:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm almost certain that Parry Automotive has the water pump for you. If they don't have the assembly, they can re manufacture your unit back to factory spec.
The contact in the marine parts section is Jeff Tittsall - same tel as above
