Gray Marine ID
Old Marine Engine » Multi Cylinder Gas Inboards » Gray Marine ID « Previous Next »
yamahauler
Username: yamahauler
Posted on Thursday, April 17, 2014 - 08:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Folks, I have a 1951 Lyman that has what I think is a gray 620 in it. I cant find a tag on it anywhere. The casting on the side of the block reads Y 400 A with some unreadable digits stamped after that and on the head it reads Y 400 A 418. I also found a 262 stamped on the back of the block below the head. Any ideas? Thanks
drrot
Username: drrot
Post Number: 168
Posted on Friday, April 18, 2014 - 08:39 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If it has a Zenith carburetor there will be a dime sized disc on it. On the carburetor, not the flame arrestor. Post the numbers on the disc.
yamahauler
Posted on Friday, April 18, 2014 - 03:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It has a Zenith. The dime sized disc has an outer set of numbers and a inner set. The outer set is A84 then a gap and 546 2. The inner set reads 560 A then the letter S across from it. Thanks very much for any help you can give me.
drrot
Username: drrot
Post Number: 169
Posted on Saturday, April 19, 2014 - 08:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Struck out. S560A was originally on a Le Roi
yamahauler
Posted on Saturday, April 19, 2014 - 08:50 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for checking for me.
