Paul Childerhose
Member Username: gt4
Post Number: 5 Registered: 10-2014
| Posted on Monday, November 03, 2014 - 04:59 pm: |
Hope you got these pictures Richard. I'm not to swift at this computer stuff. Last try then I will have to try something else |
Post Number: 3402 Registered: 11-2001
| Posted on Monday, November 03, 2014 - 07:13 pm: |
* Paul's Photos
Paul Childerhose
Post Number: 6 Registered: 10-2014
| Posted on Tuesday, November 04, 2014 - 04:24 am: |
Thanks for posting the pictures Richard.I hope someone can tell me the approx year and some info on it. |
miro forest
Senior Member Username: miro
Post Number: 777 Registered: 11-2001
| Posted on Tuesday, November 04, 2014 - 04:51 pm: |
My observations: Uses a gib key to hold the flywheel - early Has a check valve - 2 port engine Has a split crankcase - later Has cast in place passages to grease the main bearings - later Has a 4 bolt water cooled head thus lower compression - early Has a carburator not a mixing valve - later Crankshaft looks to be about 7/8 in - early The base of the timer adjustment rod looks to be cast into the crankcase - thus - factory , but the upper end seems not factory Has no provision to oil the cylinder - thus oil was mixed with gasoline - later I shuddered when I saw the 2 small bolts drilled and tapped into the water jacket of the head - ouch ! The screws are Robertson headed screws - Canadian ( also the Mastercraft table saw in the background - Canadian Tire house brand Early - pre-1907 Later - post-1907 Any info and where it came from? A barn find? A "old guy" etc miro |
Paul Childerhose
Post Number: 7 Registered: 10-2014
| Posted on Tuesday, November 04, 2014 - 06:01 pm: |
Thanks for your knowledge miro forest. I got this off a guy that said it belonged to his father in-law.He said the only thing he was told was it was 1920's era but was not sure.The father in-law died and he just wanted it gone.Do you think this is a home made jobby, or do you know what brand it might be.Oh ya your keen eye on the table saw is bang on LOL. |
miro forest
Post Number: 779 Registered: 11-2001
| Posted on Saturday, November 08, 2014 - 09:18 pm: |
The casting for the upper part of the crank case and cylinder is a complicated piece of pattern making and core work. It's not something that an individual might do for only one engine. There are many other ways of doing this, if your intention is to only make one ( or possibly two) engines. The area around the exhaust port shows that the designer was trying to improve the gas flow out of the internal exhaust port. SO I suspect that it was made by a factory somewhere. It could also be that the castings were brought in from another factory or foundry and finished into complete engines. That was a common practice although many who used this way of getting into the business did not survive very long. Our pal Richard D in Fla might have an opinion on where this might have come from. miro |
Paul
Post Number: 8 Registered: 10-2014
| Posted on Monday, November 10, 2014 - 07:07 am: |
Thanks miro for taking the time on this engine.It sounds like we're getting closer to finding out the make of this engine and model.Like you say maybe Richard d from florida will offer his opinion too. |
Post Number: 3405 Registered: 11-2001
| Posted on Monday, November 10, 2014 - 07:10 am: |
* Unfortunately this engine doesn't have a distinguishing trait that is identifiable in my system ? It goes into the "UKNOWN FILE" * |
Paul
Post Number: 9 Registered: 10-2014
| Posted on Monday, November 10, 2014 - 04:44 pm: |
Thanks Richard.I'll just be satisfied with that.I would never have got this far if not for you guys and this site. Thank you so much. |
