Wylie R Chase
New member Username: woody63
Post Number: 1 Registered: 03-2014
| Posted on Wednesday, March 19, 2014 - 10:06 am: |
Hello Folks, Please consider the pics and advise if you can help ID it. There are no name plates remaining. It appears to have had the intake and exhaust modified. Also the carb seems to be missing parts and linkage etc etc Perhaps Brown and Talbot? Thanks! W R Chase    |
Post Number: 3255 Registered: 11-2001
| Posted on Wednesday, March 19, 2014 - 06:03 pm: |
* Possible to get photos of other side and front of flywheel ? * |
Wylie R Chase
Post Number: 2 Registered: 03-2014
| Posted on Thursday, March 20, 2014 - 09:19 am: |
Richard, Thanks for response, I tried to send these last night from my phone with no luck. Please consider the attached and advise. Thanks WRC   |
douglas wesley charles
Advanced Member Username: douglas
Post Number: 33 Registered: 10-2009
| Posted on Thursday, March 20, 2014 - 10:35 am: |
Could this be a Wolverine skiff engine? They had a crank like a British twin motorcycle--both cranks in phase. |
Wylie R Chase
Post Number: 3 Registered: 03-2014
| Posted on Friday, March 21, 2014 - 10:37 am: |
I have no idea? I thought there was a solid resemblance to the Brown and Talbot. How and or where would I be able to find info on Wolverine? Any idea on vintage? Would this have had a gear box attached? Thanks! |
Post Number: 3257 Registered: 11-2001
| Posted on Friday, March 21, 2014 - 03:30 pm: |
* In my Pre 1940 marine engine data base there is only one reference to a gib keyed flywheel with 5 bolts securing it ! By looking at the design of the flywheel and the other data such as 4 cycle and caged valve chambers, I believe there is a high probability that this is the manufacturer of your engine ! This manufacturer does not show up in the Yellow or Red book by Wendel nor is it in any of Graysons's publications ? a very obscure engine, and the only one I've seen. Good luck with further research and let us know what you find ! The single in the photo is not your engine your twin a different design ? This is a 1911 article
kevin lang
Advanced Member Username: klanger
Post Number: 39 Registered: 03-2012
| Posted on Friday, March 21, 2014 - 08:47 pm: |
I am constantly amazed at the information you can find Richard. Well done sir. Kevin |
Wylie R Chase
Member Username: woody63
Post Number: 4 Registered: 03-2014
| Posted on Monday, March 24, 2014 - 08:13 am: |
Richard, Thanks for your efforts. It spins free and has compression, I am contemplating trying to make it run. Is the fab work that was done to the manifolds prohibitive? I can make new manifolds that "look" more period appropriate? Also, should I try to ID the carb for parts purposes or just look for a complete carb elsewhere? |
Andrew Munns
Post Number: 114 Registered: 04-2010
| Posted on Tuesday, March 25, 2014 - 04:15 am: |
Looks like a exhaust jacket to heat the inlet air - perhaps a kerosene option? If you can arrange pattern, foundry and machine shop, a casting might be best option. A fabrication is possibly the easiest solution but you need to be a fabricator. It will rust if used in salt water. Galvanizing a possibility but hard to get the zinc inside the jacket. Or you could keep the current manifold as this is now part of the history of the engine... Great to see the water jackets are not rust wedging. (I like to fill them with soluble oil. The Chrysler manual said to use kerosene.) |
