Free to a good home
Old Marine Engine » Palmer Engine Co » Free to a good home « Previous Next »
Mike Linbeck
Username: capt546
Posted on Monday, April 21, 2014 - 10:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Palmer 4 cylinder gas inboard with transmission that I took out of a 1974 Columbia 34' sailboat several years ago replacing it with a diesel. It was running well when it was removed and has been in dry coverage storage ever since. I will give it to anybody who wants it but I will not ship. I am located in Kemah (Houston) TX area. you can contact me at [email protected]
David Grosse
Username: davidg
Post Number: 14
Posted on Tuesday, April 22, 2014 - 11:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mike, I rebuild and recycle Palmer 60 marine engines in southern California, and would happily accept your engine and guarantee it a good future. But, I would need it shipped to SoCal.
If you change your mind, and could mount it to a pallet for shipping, I am really interested. You can see some of my engines on yachtworld.com/boatcityyachts, or on youtube.com searching for Palmer 60 engines.
Thanks either way.
- David
Peter B. Risnes
Username: vivace
Posted on Saturday, May 03, 2014 - 03:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sherwood E20 . I can't figure how to get the bearings out. I removed retaining ring and able to remove impeller & shaft but what are the steps to remove the old bearings?
David Grosse
Username: davidg
Post Number: 15
Posted on Saturday, May 03, 2014 - 04:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Peter, Thanks for the call. I am sending you two shop drawings of the water pump. One is from the Palmer manual, and the other one is a Sherwood E-20 parts diagram. You may need a shop press to get the old bearings out and the new ones in. Let me know if you want me to do it for you.
-David
larry linden
Username: lcor28
Posted on Monday, May 12, 2014 - 04:21 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello i need an intake/exhaust manifold for a palmer p60 . the engine has been rebuilt but the manifold is cracked . I tried to jb weld it but to no avail it still leaks . can anyone please help me
lscottmcleod
Posted on Thursday, April 16, 2015 - 12:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a pair of Greenwich Marine Engines MK VI-115. Can anybody tell me exactly what they are and where parts may be found. Thanks in advance for any help offered.
