Sea Dory 1936 transmission
Old Marine Engine » Gears, Transmissions, and Propellers » Sea Dory 1936 transmission « Previous Next »
David Woodworth
Username: david_woodworth
Posted on Sunday, March 02, 2014 - 08:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
n . The 1936 Sea Dory sold by Sears was made in Seattle Washington. It sold for $47 when new. To go forward you raise the engine and tighten the belt. For neutral you drop the engine one notch and it makes the belt Slack. For reverse you drop the engine on to The propeller shaft V pulley. It actually works pretty good.
miro forest
Post Number: 746
Posted on Sunday, March 02, 2014 - 10:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nice restoration
Where does it live now?
Jim Parrott
Username: jim_parrott
Post Number: 65
Posted on Monday, March 03, 2014 - 12:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That is a nice boat. Would like to see a video of its drive system in action.
Jim
