Help Identify 2 cylinder
Old Marine Engine » Unknown Engines - post here with photos » Help Identify 2 cylinder « Previous Next »
Eric Ryback
Username: motorcanoe
Post Number: 43
Posted on Monday, March 17, 2014 - 04:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Need help identifying
No-1
Dick B.
Posted on Monday, March 17, 2014 - 05:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Looks identical to my Lockwood Ash, 6 hp, #6884.
Roger DiRuscio
Username: solarrog
Post Number: 574
Posted on Monday, March 17, 2014 - 05:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think they call this the model U
Eric Ryback
Post Number: 44
Posted on Monday, March 17, 2014 - 06:22 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Dick, thank you for identification. Here is a photo of the other side.
no.2
Post Number: 885
Posted on Monday, March 17, 2014 - 10:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Eric, it's a Lockwood Ash or Motorgo, Sears Roebuck trade name for L-A. THe earliest L-A's had consecutive serial # for all motors. They changed their numbering system in the early teens, the model 24 included the 2 1/2 and 4hp, the model 68 included the 6 & 8hp. Serial # beginning with a 2, 4, 6, or 8 gave the hp, the next # were consecutive serial # for that hp. THe tag on mine is 6035, 35th engine in that series. The # should be stamped on the front of the crank, Jamie Hurry probably has a new tag for it. This motor is probably from the early to mid teens, it doesn't have the plate covering the intake ports, later engines had them, I have a picture of one below.
p
