Blaxland cooling system issue . |
John Kelly Visitor
| Posted on Saturday, February 01, 2014 - 07:12 pm: |
I am after info from anyone in regards to cooling jacket cleaning using acids etc .if it is even an option . I have a Blaxland twin that has a hot spot on one of the pots I removed the water pump and found some corrosion in the inlet valve which I cleaned out . I have back flushed the system and still have good water flow through out . Both pots run cool except for one pot lower down . Has anyone succeeded in cleaning out the corrosion as I'm sure it's a common issue. If not who does cylinder pots at a reasonable price . ?? Any info would be appreciated . Thanks for your time . |
