Universal Engine Co Flexi-four
Old Marine Engine » Multi Cylinder Gas Inboards » Universal Engine Co Flexi-four « Previous Next »
bruce
Username: bruce
Post Number: 417
Posted on Tuesday, December 31, 2013 - 03:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Who is the Universal 4 cyl engine Guru here? Did Universal cast their own blocks? Is there still a working web site for Universal Engine History?? Where can rebuild parts be found for other than Atomic four engines? THanks
Post Number: 1770
Posted on Wednesday, January 01, 2014 - 08:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bruce,
Not an expert but I sure worked on a ton of them way back when.
I think the early ones were mostly all universal.
Starting in the 50s they were mostly if not all Hercules blocks.
They also Marinised the 225 cu in Buick V6
The current Universal engines are Kubota Marinised by Westerbeke in Taunton, MA
I just found this on the net
http://www.shadowmagic3d.com/BlackSwan/uh.html
Hope this helps
bruce
Username: bruce
Post Number: 419
Posted on Wednesday, January 01, 2014 - 11:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks much Ernie for locating the Universal marine engine co. history, I appreciate it.
