Gray Marine Phantom Four
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine Phantom Four « Previous Next »
Paulo
Username: pfgees
Posted on Sunday, October 20, 2013 - 11:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can somebody help me with the identification, model or other information, of my Graymarine 4 cylinder gasoline Phantom four. There is no identification plate left on the gearbox. On the engine itself it's got the nr's: TUPY 2
81-03-001
15B85
CSTG Y400A-617
Any info is appreciated.
Thx, Paulo. (Amsterdam, The Netherlands)
Jim Staib
Username: drrot
Post Number: 160
Posted on Monday, October 21, 2013 - 09:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paulo,
There should disc with numbers on the carburetor.
What are the numbers?
Paulo
Username: pfgees
Posted on Wednesday, October 23, 2013 - 04:09 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim, I never knew there was a tag with information on the carb.
This is the info:
U.S.C.G. APPR
162 041 880
B175 19
I hope you can do something with this information. Paulo.
Jim Staib
Username: drrot
Post Number: 161
Posted on Wednesday, October 23, 2013 - 10:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That tag is on the flame arrestor. There should be one just like it on the top of carburetor.
Paulo
Username: pfgees
Posted on Sunday, October 27, 2013 - 03:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim,
I found the little disc you were talking about.
It is hard to read but it says: 85198
Thank You for so far, Paulo.
Jim Staib
Username: drrot
Post Number: 162
Posted on Monday, October 28, 2013 - 09:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paulo,
This is as close as I could find.
Is there a chance it is 8819B?
Gray specs
Paulo
Username: pfgees
Posted on Monday, October 28, 2013 - 03:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim,
I think you're right about the last digit, a B instead of a 8. That means: 8519B
Disc
Jim Staib
Username: drrot
Post Number: 163
Posted on Tuesday, October 29, 2013 - 10:58 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paulo,
8519B does not show up in my books.
I'm guessing it is 8819B that is poorly stamped.
JIM
Paulo
Username: pfgees
Posted on Tuesday, October 29, 2013 - 05:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim,
Thank you for your effort.
It's great to know more about my engine.
If it is not to much work, could you send me the whole document of the appendix you sent on monday?
Thx again, Paulo.
