1978 Ford 302 Firing Order
Old Marine Engine » Multi Cylinder Gas Inboards » 1978 Ford 302 Firing Order « Previous Next »
65hydrodyne
Username: 65hydrodyne
Posted on Monday, January 31, 2005 - 02:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello, I need the firing order for a 1978 ford 302 standard rotation marine engine. Also if someone could tell me the proper spark plug gaps for this engine I would be most grateful.
Thanks for the help.
Hodrico M.
Key Largo FL
Post Number: 228
Posted on Monday, January 31, 2005 - 08:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It should be 15426378, 1234 on the right looking from the trans, 5678 on the left.
65hydrodyne
Posted on Monday, January 31, 2005 - 11:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Jb, just to clear things up for myself...The first and fifth cylinder are closest to the trans,(rear) on the marine blocks, like in my crude diagram? Or is it the same as auto blocks and the first and fifth are closest to the front(pulley) side of the engine. Thanks for your patience with me.
Hodrico M.
Key Largo FL
pulley(front)
|4|______|8|
|3|______|7|
|2|______|6|
|1|______|5|
Trans(rear)
Post Number: 229
Posted on Tuesday, February 01, 2005 - 01:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Number one would start from the pulley end.
Rusty Boat
Posted on Monday, February 07, 2005 - 10:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JB, The numbers of each cylinder should be raised
cast-in numbers on each intake runner leading to each cylinder close to the head?
gayfag
Posted on Friday, July 13, 2007 - 10:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
.l,mnf,lndslkhfgdfhdf
hondoboat
Username: hondoboat
Posted on Wednesday, July 25, 2007 - 09:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
what is involved in changing the rotation of an engine,,4.3 v6 vortec starter camshaft gears etc.---
Post Number: 268
Posted on Wednesday, July 25, 2007 - 11:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If you can get a two gear drive instead of the chain, a reverse starter, and reverse water pump you should be ready.
hondoboat
Username: hondoboat
Posted on Thursday, July 26, 2007 - 07:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
is it ok to install two engines rotating same direction in a twin vdrive installation
28ft boat
andys
Username: andys
Posted on Friday, July 27, 2007 - 05:10 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
many pre-war and WWII boats did this for simplicity, so yes. You will have to get used to the way that the stern kicks over and will find it much easier coming alongside one side rather than the other. depending upon your hull and VCG, especially if a narrow deep-V then the torque in the same direction may noticibly heel the boat over.
bradore
Posted on Monday, October 14, 2013 - 09:07 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
how do i know which way the engine should trun frod 302
Post Number: 834
Posted on Monday, October 14, 2013 - 04:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Standard rotation on a Ford V8 is CC while facing the engine from the front.
