One , two, three, FLIP
Old Marine Engine » Boats with Early Inboards » One , two, three, FLIP « Previous Next »
Post Number: 715
Posted on Friday, August 30, 2013 - 08:43 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here is how I flipped my boat ( a 1910 fantail launch) over.
The slings were clamped to the gunwale, with one side really long and the other side really short.
I then cranked the come-alongs a bit at a time on each side until the boat was at "top-dead-centre" at which point it was easy to control it.
Sawhorses were then place underneath the gunwales and the clamps released and VOILA - boat is flipped.
1
2
3
Post Number: 716
Posted on Friday, August 30, 2013 - 09:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
A couple more pictures of the boat.
You can see that the space in the boathouse is quite limited.
1
2
Post Number: 827
Posted on Saturday, August 31, 2013 - 05:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Good job Miro, the boat looks great. What's going to power it?
Post Number: 1716
Posted on Saturday, August 31, 2013 - 07:24 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Neat!
What is it coated with?
Post Number: 717
Posted on Sunday, September 01, 2013 - 06:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It will have the 1918 two cylinder St Lawrence - I'm still debating whether or not to install a FNR gear ( I have 2 of them) . I like the idea of reversing on the switch - makes for a simpler installation but starting at a dock may present some challenges ( eg hitting another boat)
The coating is a thin layer of coloured epxoy
The hull is 13/16 in old growth cypress made with a cove and bead technique - which makes it essentially unrepairable especially since iron nails were used to edge nail the strips.
I looked at some of the wood that I had to remove under a 20x microscope and counted about 40 rings to the inch.
raa
Username: raa
Post Number: 56
Posted on Sunday, September 01, 2013 - 08:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
really neat looking boat Miro sure wish we were closer.I can appreciate the need for a fnr transmission. save wear and tear an the neighbors boats!
cheers
dick
raa
Username: raa
Post Number: 57
Posted on Sunday, September 01, 2013 - 09:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
here is another way to flip a small boat. the old jib sheet simply slipped thru the hooks on the two chain hoists. the boat is my 1907 tuttleTittle 1
keith
Username: keith
Post Number: 397
Posted on Sunday, September 01, 2013 - 09:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Miro, Glad to see you are back on the project.
