6 Cyl Gray Marine Engine ID help and ... |
Larry Nordman
New member Username: larry_n
Post Number: 1 Registered: 09-2013
| Posted on Monday, September 16, 2013 - 05:11 pm: |
Hi, can anybody help identify this 6 cyl Gray Marine model? The id plate is missing. The head does have A600A on casting and a plate with number 92758 on it. It has two Zenith updraft carbs. I am also looking for a coil and ballast resistor replacement part numbers. the brass tag on carbs is 11815. Please see attached photos. Thanks, Larry |
Jim Staib
Senior Member Username: drrot
Post Number: 156 Registered: 09-2008
| Posted on Tuesday, September 17, 2013 - 08:56 am: |
1955 135hp |
Larry Nordman
Post Number: 2 Registered: 09-2013
| Posted on Wednesday, September 18, 2013 - 09:14 pm: |
Thank you Jim! Did this model have a name? Does anybody have an idea as to what coil and ballast resistor will work and where to get them? |
Jim Staib
Post Number: 157 Registered: 09-2008
| Posted on Thursday, September 19, 2013 - 08:28 am: |
The NAPA book says IC7 for 6 volt and IC14 for 12 volt. My book is from the 1960s so check to see if the part numbers are still the same. |
