Cameron
New member Username: cammo
Post Number: 1 Registered: 11-2012
| Posted on Saturday, November 10, 2012 - 02:04 am: |
Well this is my first post so ill introduce myself first, The name is Cam, i have played with engines for as long as i can remember. Always wanted an old engine to restore but could never find one. WELL i found one! Did my best to search google for information about this engine. could not move it to find a plate.. but its mine if i want it. Any idea as to what this engine is? Any help is appreciated Higher Quality image: http://www.freeimagehosting.net/jvkfu
miro forest
Senior Member Username: miro
Post Number: 637 Registered: 11-2001
| Posted on Sunday, November 11, 2012 - 09:55 pm: |
If I were you, I'd definitely capture this one. Looks as if it has the original primer and a really interesting spark plug - certainly not one that I have seen before. It's probably made after the introduction of oil / gasoline mixing i.e. 1910 - 1911. And it doesn't look as if it has been stored out in the weather so it's probably going to be easier to free up.Looks like a 1 in carb will do the trick. Happy haulin' miro |
Matt Morehouse
Senior Member Username: matt_morehouse
Post Number: 129 Registered: 12-2009
| Posted on Sunday, November 11, 2012 - 11:43 pm: |
Sure looks to me like a diesel injector on the top. I don't see any spark plug. |
Cameron
Post Number: 2 Registered: 11-2012
| Posted on Monday, November 12, 2012 - 12:48 am: |
Thanks for the replies so far. From what i can remember looking at the engine, there is a spark plug (or glow) at the rear of the head. (marked in this picture) One of the blokes i work with reckons its a Lister marine. but again i can not find anything on google!
Stephen Dorey
Member Username: steved
Post Number: 6 Registered: 06-2009
| Posted on Monday, November 12, 2012 - 07:43 am: |
If all I could see of this engine was the very top I'd think I was looking at my 1970's Yanmar diesel. The setup looks identicle right down to the shape and thickness of the strap securing the body as well as the apparant diameter of the body. The flats on the body above the strap are for disasembling the injector. Obviously this is a much earlier engine but the similarity is remarkable. The injector(?) is held in by the strap secured by the two studs to either side of the body. The body is not screwed into the cylinder. It just drops in. My injector has an O-ring at the base of the body to complete the seal. I'm not sure they had O-rings or the lathes required for the extremely close tolerances of a diesel injector unless this is a much newer engine than it appears. Probably a good soak with penetrating oil will be needed to free it. |
Cay Small
Member Username: seagal007
Post Number: 16 Registered: 07-2012
| Posted on Monday, November 12, 2012 - 11:45 am: |
It sure does look like an injector Could the engine have been started on gas then switch fuels once warmed up? |
steve marsh
| Posted on Tuesday, November 13, 2012 - 09:27 pm: |
I agree with miro,go ahead and get it.That looks like a 'piston break' or 'compression break' ignitor that is hard to find intact. |
Cameron
Post Number: 3 Registered: 11-2012
| Posted on Sunday, August 11, 2013 - 09:20 pm: |
Hi all, Thanks for the help with this, bit of an update. I managed to get back and have a look at this engine again. Its mine now, just have to pick it up! So I found a plate. Looks like we are looking at a Chapman marine diesel. Though I know nothing more than that. And I can not seem to find any information or pictures of this model. In the picture I can not make out the lower line of text. http://www.freeimagehosting.net/t/g74f3.jpg |
Eric Schulz
Senior Member Username: eric_schulz
Post Number: 79 Registered: 01-2007
| Posted on Monday, August 12, 2013 - 12:26 am: |
That's a very rare engine you have there. The only Chapman I had seen illustrated was the 15hp, introduced in 1933. There was a 10hp lightweight advertised from Sept 1937, but no photo. Is yours big enough for 10hp? No technical data on the 10hp, but the 15hp was a petrol start type. Quite a complicated and heavy engine. I can't recall seeing a diesel with a non-detachable head either. Most unusual. More photos would be appreciated. Eric |
Andrew Munns
Post Number: 92 Registered: 04-2010
| Posted on Monday, August 12, 2013 - 02:33 am: |
Wow! John Forrest described to me a delivery trip from Sydney to a port south (Narooma?) in an open boat powered by a Chapman diesel. John was the apprentice and naturally was given the delivery trip to undertake. He said that only 6 diesels were built! John said they were a bit experimental. A surviving Chapman diesel is therefore well beyond just being rare - I have never even seen a photo. They started on petrol and had a carby and magneto (as did the much bigger Kelvins), and then switched over to diesel, or oil. John said starting was easy. I do have some brochures on them and will dig out and scan. |
Jack Timms
New member Username: captain_jack
Post Number: 1 Registered: 02-2012
| Posted on Monday, August 12, 2013 - 06:49 am: |
Hi Eric, I thought you would have caught this first time around. The flywheel and the crankcase are a dead giveaway as being from the Chapman stable. Wayne |
Cameron
Member Username: cammo
Post Number: 4 Registered: 11-2012
| Posted on Monday, August 12, 2013 - 07:23 am: |
Eric, it would have to come close to 10hp. its large and heavy. From looking at other pictures of 10hp vintage engines, its very close. Andrew, Lets hope it is indeed one of those surviving engines! would be a very lucky find. it is interesting you mention about the petrol starting. The object that i had marked with a red ring in the previous photos looks to be a spark plug. when i had a closer look at it the other day i was sure it was. unless glow plugs used a porcelain jacket?? The owner told me the engine was in the shed when they purchased the house. over 60 years ago.
Eric Schulz
Post Number: 80 Registered: 01-2007
| Posted on Monday, August 12, 2013 - 08:17 am: |
This is the 15hp engine. Weight with reversing gear as shown is 1800 pounds or 816kg. Eric
Cameron
Post Number: 5 Registered: 11-2012
| Posted on Monday, August 19, 2013 - 03:02 am: |
Seems to be a lot of similarities to the 15hp. Maybe it is the 10hp after all. Have been trying to look for more info almost every day now. Looks like it will be tougher that I first though to find some in depth information on this engine. Would love to know its history. |
Wayne Timms
Post Number: 2 Registered: 02-2012
| Posted on Monday, August 19, 2013 - 05:18 am: |
Hi, I have to disagree a little. I think it resembles the engine I first suggested. See the link : http://www.smokstak.com/forum/showthread.php?t=112243 It may even be using some of the same parts. Regards, Wayne |
Scott Forrest
New member Username: gsonofjf
Post Number: 1 Registered: 08-2013
| Posted on Thursday, August 22, 2013 - 03:33 am: |
Hi there, I am the Grandson of John Forrest and I can recall the story you mention below. He was alone in the boat and the lights went out. He lost sight of the coast line and was in a difficult position. He mentioned about 30,000 times how reliable the engine was and the faith he had in not getting stuck in the high seas. Anyone who knew or met my Grandfather would know his love for these engines (Chapman). He would describe the engines as being very easy to start and reliable as ever. He often held my arm nearly breaking it demonstrating just how they started. I must have told him a thousand times that my arm is not a flywheel. Anyway just thought I would place a little light on your interesting topic. Nice find, would be great to see in action. "Wow! John Forrest described to me a delivery trip from Sydney to a port south (Narooma?) in an open boat powered by a Chapman diesel. John was the apprentice and naturally was given the delivery trip to undertake. He said that only 6 diesels were built! John said they were a bit experimental. A surviving Chapman diesel is therefore well beyond just being rare - I have never even seen a photo. They started on petrol and had a carby and magneto (as did the much bigger Kelvins), and then switched over to diesel, or oil. John said starting was easy. I do have some brochures on them and will dig out and scan." |
Cameron
Post Number: 6 Registered: 11-2012
| Posted on Thursday, August 22, 2013 - 04:42 am: |
A great story Scott. They certainly sound like a great engine. Does anyone have any scans of any documents on this engine? I have a few on the seadog and the block of this engine looks identical. The head looks to have a few differences. Picking it up in 2 days. Lots of photos to come. Hopefully I wont have to find a pump for the fuel! |
Scott Forrest
Post Number: 2 Registered: 08-2013
| Posted on Thursday, August 22, 2013 - 05:04 am: |
When I get spare minute I will have a look for you, I have a lot of documentation and manuals. Is there a particular name/model that you can reference to assist my searching? |
Cameron
Post Number: 7 Registered: 11-2012
| Posted on Thursday, August 22, 2013 - 06:47 am: |
That's very kind of you, much appreciated. At the moment all I have it the details on the plate: Chapman patent diesel engine. In the picture I took the lower line of text on the plate was a bit too blurred to read. And I don't think its the 15hp diesel. Will have more info in a couple of days. |
