Garry Edwards
| Posted on Monday, August 09, 2004 - 10:09 pm: |
Does anybody have info on Simplex Thrustmatic marine gearbox |
marks
Advanced Member Username: marks
Post Number: 67 Registered: 03-2002
| Posted on Tuesday, August 10, 2004 - 08:15 pm: |
Garry What do you need to know? Mark S. |
Gary Haywood
| Posted on Sunday, October 31, 2004 - 08:58 pm: |
Full photocopy of the Simplex manual with additional notations is available for A$20 + postage from Roger Prettyman at the Simplex Manufacturer: Hardman & Hall 3 Stanton Road Seven Hills NSW 2147 Roger's email contact is: [email protected] I know this because I am considering refurbishing a single cylinder simplix and Roger has been helping me with parts availability and prices. I would be interested to learn what your interest is. |
Laurie smith
| Posted on Wednesday, June 03, 2009 - 04:58 am: |
i have just came by simplex single c/w gearbox all parts are available from hardm an and hall in sydney, I need a maggy and possibly ahead, I wonder iff the cast heads are repairable |
Todd Vidgen
Post Number: 124 Registered: 03-2008
| Posted on Wednesday, June 03, 2009 - 06:02 pm: |
If your head is rusted out/cracked,then the chances are the block is not far behind. Heads from H&H are $350,complete blocks(valves,guides,studs,etc)$1951. Word of advice.WASH the parts thoroughly as quite often casting sand is still in them,especially in the intake port.They will also sell you a maggy at a price |
Todd Vidgen
Post Number: 125 Registered: 03-2008
| Posted on Wednesday, June 03, 2009 - 06:11 pm: |
Ps .Roger is no longer there.Geoff now looks after this department. The simplex part of their business wouldn't be a quarter of one percent of what they do. Their main line is engineering gears and components for the mining industry.So dont expect to ring up and have a long chat about your engine . Nice people but very busy. |
Russell Mcculloch
| Posted on Friday, October 09, 2009 - 05:11 am: |
Dose any one know or have a picture of set up of dog clutch to engine 5hp simplex |
Todd Vidgen
Post Number: 140 Registered: 03-2008
| Posted on Sunday, October 11, 2009 - 04:56 pm: |
If it is a 5hp 4stroke the gearbox is part of the main casting and it is a band/finger reverse gear type box,no dog clutch fitted The other gear box they use is on the 10/12 twins and the model D 4 cycle 6-7 hp Thrustmatic, which is a cone clutch type. The earlier reverse gear type was adjusted by tightening the nut on the reverse gear cam swivel (for reverse) and adjusting the set screws on the 3 brass figers for the forward gear(dont over tighten these as you can break the fingers) The thrustmatic is a bit more complex as you have to take the gear box apart and add or subtract shims and spacers.Gasket shims between the engine and gearbox operating housing for fwd gear adjustment 1/64th and 1/32nd shims are used. 5/16",1/64",and 1/32" spacers are fitted on the output shaft between the cone and the slider. A point to note is if you adjust one you have to adjust the other |
Russell Mcculloch
| Posted on Thursday, November 15, 2012 - 04:04 am: |
To those that are interested i now have a bracket made for a 5 HP simplex marine engine to suit a starter generator yamaha that makes it very easy starting and producing power for all those accesaries you you might want |
Laurie Derwent
Post Number: 123 Registered: 10-2009
| Posted on Friday, November 16, 2012 - 12:34 am: |
Thanks Russell, Are you able to provde the deatils of the Yamaha stater/generator. Are they readily available in Oz? Regards laurie |
Peter Halverson Visitor
| Posted on Tuesday, August 20, 2013 - 01:04 am: |
Hi guys if you want a starter motor generator try Cheaper Cart Parts, I have just bought one for my Simplex @ $399.00 as opposed to about $1200 for the Yamaha model the business advertises on the net and can be contacted at 0408485108, Phil sells Golf cart parts and as sourced these from Canada as a cheaper alternative to the Yamaha models |
