ID small marine engine
Old Marine Engine » One and Two Cylinder Gas Inboards » ID small marine engine « Previous Next »
mark_gross
Username: mark_gross
Posted on Friday, August 16, 2013 - 08:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Guys, Can any one give me an idea on what marine engine this is Make, Model, HP and is it possible to get parts for it? Regards Mark
marks
Username: marks
Post Number: 152
Posted on Saturday, August 17, 2013 - 05:09 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Mark,
It as 2 1/2 HP Blaxland. They are quite a nice little engine. Your best bet for parts is to find another one as there are quite a few around.
Cheers,
Mark
johnoxley
Username: johnoxley
Post Number: 93
Posted on Saturday, August 17, 2013 - 06:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Perhaps a bit more detail pls... clearly Chapman, but looks a bit more industrial than marine? Can anyone explain plus explain the vee gorrve arrangements? Also the cast lug on the 'head'.
klanger
Username: klanger
Post Number: 30
Posted on Saturday, August 17, 2013 - 06:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Couple more photos would help. I too wondered about the lug on the cylinder. It does look like a marine engine set up as a stationary engine.
mark_gross
Posted on Saturday, August 17, 2013 - 06:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Guys, Not sure about the lug on the head, I've seen a few engines on the net but nothing like this one, the magneto has no maker on it as well mark
mark_gross
Posted on Saturday, August 17, 2013 - 06:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
HI Marks, Do you have any photos of this type of engine. Mark
gregoryan
Username: gregoryan
Post Number: 108
Posted on Saturday, August 17, 2013 - 10:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
what an amaazing Spark Plug! I'd love to see a close up of it!? Is there any writing on it?
I have a picture of a similar model engine as a portable water pump/engine, i think it was an original unit by Chapman[ but without the cylinder head lug, and the more common mag drive & flywheel] . My point being that maybe there were a few non-marine Chapmans!?
mark_gross
Posted on Saturday, August 17, 2013 - 11:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Gregoryan, the spark plug is a splitdorf there is currently one on ebay ta the moment, can you post a photo of yours mark
klanger
Username: klanger
Post Number: 31
Posted on Saturday, August 17, 2013 - 11:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Did chapman make an engine like this? It looks like the cylinder is cast with the top half of the crankcase.
mark_gross
Posted on Sunday, August 18, 2013 - 12:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
NOt sure but Yes the cylinder and top half of the crank case are cast in one.
If any one has a carbie bowl lid I'm happy to make use of it
Also did these engines have the water flowing through the exhaust? Mark
gregoryan
Username: gregoryan
Post Number: 109
Posted on Sunday, August 18, 2013 - 05:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The 2.5 and 3 HP had a single casting for the head + cylinder + top-half crankcase.
The stationary Chapman / Blaxland pic i have shows a wet exhaust and driving a grear type pump? splitdorf spark plug huh! I'll look on ebay thanks mark!
Chapman/ Blaxland pump
Oh Wow!; I just noticed in the pic there is a BR emblem on the baseplate!;,, this means Blaxland Rae. The same emblem is on some of the carbies too.
mark_gross
Post Number: 7
Posted on Sunday, August 18, 2013 - 04:53 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks,Gregoryan, So they made these as stationary s as well,
Can these engines run on a dry exhaust with out any problems.
Going on the magneto and gear and maybe the spark plug that came with the engine, my engine maybe a very early one?
I'm chasing a carbie lid if you know were I can get one! Mark
eric_schulz
Username: eric_schulz
Post Number: 81
Posted on Sunday, August 18, 2013 - 09:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This engine is a Chapman Pup. It is too old to be a Blaxland, which came into existance in 1938. And, as far as I know, always had a detachable cylinder barrel.
The bevel drive magneto indicates that the engine was made between 1926, first year of the Pup, and 1930. I do not have enough photos to pinpoint the change from bevel drive to skew drive. It may have been before 1930.
Chapman engines certainly were used for stationary purposes, and were advertised as such, including kerosene versions.
The lug on the cylinder is a mystery, as is the carburettor. I had not seen one like that, but I have not seen a lot of Chapman engines, living well inland as I do.
The 1936 ad below shows a Pup driving a generator. There was also the Model A for stationary use with a direct drive magneto. The direct drive magneto was also used on the Export model. The Standard having the vertical magneto. Then there was the Deluxe Standard, somewhat of a contradiction in terms.
Splitdorf spark plugs had mica insulators, not uncommon in the old days. They were different because of the green jacket that covered the mica.
I always imagined that the water going through the exhaust muffler was to cool it for the comfort of the passengers. A dry exhaust will not hurt the engine.
Eric
mark_gross
Post Number: 8
Posted on Sunday, August 18, 2013 - 11:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks,Eric. Going on the engine Ad that you attached, it has the same carbie as mine and going by the magneto and spark plug,the years you mentioned would be pretty much right, Now it's just time for me to collect a few parts for it and make a display together,thanks, Mark
