Doug kimball
Member Username: doug11k
Post Number: 28 Registered: 12-2003
| Posted on Thursday, July 20, 2006 - 03:06 pm: |
Here is an image from a 1910 Montgomery Wards catalog that recently sold on Ebay. It showed mostly farm engines but this one page shows Wards 'Admiral' engines which I believe were manufactured by Dunn Motor Works. |
Post Number: 1180 Registered: 11-2001
| Posted on Thursday, July 20, 2006 - 07:55 pm: |
Doug Great old ad, Had the Admiral tradename but not the photo ad, they are Dunn mfgd engines- another mystery solved !! |
Chuck Franklin
New member Username: chuck
Post Number: 2 Registered: 05-2005
| Posted on Saturday, September 23, 2006 - 11:41 pm: |
I just picked up a Dunn engine and am looking for info. it is a two cylinder with the time driven off the end of the cam shaft next to the prop shaft coupling. I can not find any oil pan or crankcase side or any place to mount or bolt to the engine frame. Can anyone give me any idea what year, where is the serial number located or any other info. The engine is in fair shape, however i will need sleeve the cyliners back to original, plus locate a carborator. |
Post Number: 1224 Registered: 11-2001
| Posted on Sunday, September 24, 2006 - 12:16 am: |
Hello Chuck: Good hearing from you, click on the search heading above and type in Dunn- lots of good photos and info there. Email me or post some photos and I can probably date your engine pretty close! Richard [email protected] |
Post Number: 1774 Registered: 01-2002
| Posted on Sunday, January 05, 2014 - 10:20 am: |
Has anyone some up with a Dunn add showing the engine with a carb on it? Just wondering what Dunn originally used. As to actual engiens they have showed up with just about any carb you can think of. From looking at all the Dunn pics on here and elsewhere the most common is a Model T Ford. |
Post Number: 3183 Registered: 11-2001
| Posted on Sunday, January 05, 2014 - 12:21 pm: |
* 1908 and 1910-11 catalogs show this info.
later catalogs show no carbs or even mention them ? * |
Post Number: 1775 Registered: 01-2002
| Posted on Sunday, January 05, 2014 - 07:29 pm: |
Thanks |
