Brandon Pineo
Member Username: bpineo
Post Number: 22 Registered: 05-2008
| Posted on Sunday, June 02, 2013 - 05:34 pm: |
Hello everyone. I am writing today to see if anyone can direct me to a source for small diameter brass or bronze propeller shaft. I am in need of a replacement for my inboard canoe. The diameter is 5/8 inch. Any suggestions would be much appreciated. |
Post Number: 1679 Registered: 01-2002
| Posted on Sunday, June 02, 2013 - 07:47 pm: |
Tucker Reynolds Reynolds Marine 10 Spring St Deep River, CT 06417 Phone Number: 8605261055 |
Andrew Munns
Post Number: 80 Registered: 04-2010
| Posted on Sunday, June 02, 2013 - 08:57 pm: |
Hi - Think about which alloy brass. 60/40 Brass (Muntz metal) is going to dezincify in salt water. 70/30 (Cartridge Brass)is better. If a salt water boat, I'd go for 316 Stainless. Might be cheaper as well. |
Bruce Hall
Senior Member Username: bruce
Post Number: 379 Registered: 07-2002
| Posted on Monday, June 03, 2013 - 07:27 am: |
Brandon, Any pictures you might share of your motor canoe please?? Bruce |
Brandon Pineo
Post Number: 23 Registered: 05-2008
| Posted on Monday, June 03, 2013 - 08:11 am: |
Thank you very much! Ernie, I have the Palmer by the doorway now, and I can bring it any time that is convenient for you. Also, you should see the Lathrop 3 HP that Ray just found! 1920 ish and crusty, but very savable! Nice size engine. Bruce, I have the engine for the canoe all fitted up, and have removed it to work on the shaft log/ skeg. As soon as I right the canoe, I will share some pics of the whole unit. Thanks for your interest! |
Post Number: 1680 Registered: 01-2002
| Posted on Monday, June 03, 2013 - 08:56 am: |
Give me a call. The number you called the other day was my office. Use the 774 number |
Bruce Hall
Post Number: 380 Registered: 07-2002
| Posted on Monday, June 03, 2013 - 01:23 pm: |
Brandon, I made the connection now, You are the stove doctor with the "GREEN" canoe. Bruce |
