Kingfisher single crankcase half?
Old Marine Engine » One and Two Cylinder Gas Inboards » Kingfisher single crankcase half? « Previous Next »
bpineo
Username: bpineo
Post Number: 21
Posted on Saturday, March 30, 2013 - 08:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know where I could get a kingfisher aluminum crankcase front half? I am prepping one for my canoe, and found small fractures around the crank drain plug hole. Any leads or advice for repair with old aluminum would be very helpful.
mechman
Username: mechman
Post Number: 27
Posted on Sunday, March 31, 2013 - 05:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Goodday. Most welding shops have TIG welding machines (Tungston inert gas) It should be a relatiively easy repair. --Good luck Larry H.
Post Number: 689
Posted on Sunday, March 31, 2013 - 11:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Since it doesn't sound to be a structural flaw, you could probably get away with good ol' JB WELD . I know it stands up to heat well, and is routinely used for repairs on crankcases.
You'll need to make sure the repair area is very clean.
Any kind of welding will put enough heat into that casting to potentially cause distortion.
If you go the welding route, take goods measurements of flatness of the mating surfaces before you do it so you'll have a reference.
Post Number: 1627
Posted on Monday, April 01, 2013 - 11:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I vote for JB Weld as well
