Oil change on a gray marine six 104? |
alexandre
New member Username: alex_92
Post Number: 2 Registered: 09-2014
| Posted on Wednesday, September 03, 2014 - 07:07 am: |
Hello there, Could you tell me how and where to drain the oil on a six gray marine 104? Thank you very much for your help friendships Alex |
Pete Oquist
Member Username: 1955_century_resorter
Post Number: 7 Registered: 08-2010
| Posted on Wednesday, September 03, 2014 - 11:34 am: |
Alex, I use a "Big Boy Topsider" kit to change the oil. Stick the tube down the dipstick and siphon the oil out. Also, remove the top plate on the transmission as there will be some oil in there as well. It helps a lot if you can drain it when it is warm. Hope this helps. |
alexandre
Member Username: alex_92
Post Number: 4 Registered: 09-2014
| Posted on Wednesday, September 03, 2014 - 11:53 am: |
A big thank you for your reply. sorry I was not clear in my question. Since there is no oil filter outside of the engine, is there a filter to clean house? A big thank you in advance, Alex |
